89 to 91
Car: 87 mustang gt 89 camaro
Engine: 302 355 tpi
Transmission: manual
Axle/Gears: 3.55 and 3.42 posi
89 to 91
i am wapping an 89 305 tpi for a 91 305 tpi...will i need to change the computer and wiring harness..also is there any other things taht may be different?
Car: 1989 gta
Engine: L98 D1SC procharger twin IC
Re: 89 to 91
im pretty sure in 1989 they used a maf sensor and in 1991 they went to map sensor ...so yes you would need a different computer ..
Re: 89 to 91
Just put the 89 TPI top end ont he 91 motor.
The motor itself is the same (or at least, plenty close enough); just put the right stuff on it to work with the electronics and wiring that are in the car.
Engine: 302 355 tpi
Re: 89 to 91
ok this is what ill do...what parts need to be swapped over...the intake manifolds should be the same right?
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: 89 to 91
Nope. The intakes are different. You need to just use the block and heads from the 91 and then bolt all of the 89 parts back to it.
Engine: 302 355 tpi
Re: 89 to 91
the 91 is going from an auto to a manual..is there any differece or it will it bolt directly on
Transmission: 4L80E/4L80E
Re: 89 to 91
No difference as far as the engine is concerned. You will need to install a pilot bearing in the crank.
Engine: 302 355 tpi
Re: 89 to 91
are u sure the intakes are different...by the egr the casting # is the same.
Engine: 2.8/TBI/TPI
Re: 89 to 91
I can't say which part is different. I think MAF engines use a 7th fuel injector for cold start, but maybe GM dropped that for the 89 MAF engine. The fittings and sensors going into the intake will also be different, maybe? I just think it's better to use the entire 89 setup so that no little mistakes get made, like forgetting a sensor but not knowing where it goes because your new intake has a plug in it instead of a sensor.
Re: 89 to 91
Oooopps!!!! Been looking at a 2.8 too long Kris?This is a V8.
That'd be a 9th injector.But that goes into the runners, not the base. AFAIK the 91 base is the same as 89, but I could be wrong.
So yeah, keep your old plenum, TB, runners, wiring, sensors, and so forth; just use the other long block and out that stuff from your car onto it. Anything from the 91 that's the same as the 89, use it; anything on the 89 that's different from what's on the 91, use the 89 stuff. Pretty straightforward.
Engine: 2.8/TBI/TPI
