LG4 swap to L83
Car: 1983 Trans Am MSE
Engine: LG4
Transmission: TH700R4
Axle/Gears: 10 bolts 3.73
LG4 swap to L83
Hi
i have a 1986 trans am with a 305 LG4 but i want a 350 or more, i have found a L83 from a 1984 corvette so i want to swap it into the trans am and swap the crossfire to a tpi .
is it possible
is it possible
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: LG4 swap to L83
Very possible. Under the intake manifold, its still just a small block Chevy.
Transmission: 4L80E/4L80E
If the cylinder walls are extremely clean, you can do that. The typical 3.75" stroke kit includes pistons that are .030" oversize, because the typical block used for this exercise needs a clean-up overbore. That bumps the displacement to 383 cubic inches.
Engine: LG4
Re: LG4 swap to L83
yes, if the cylinder are not in good shape i will overbored to 4.030" with a 3.75 crankshaft to do a 383 .
Hello, Michael
Aug 20, 2015 03:19 PM
