Is this 350 a good deal?
Car: 82 Camaro; in process of resto
Engine: 350 4bbl.
Transmission: 700R4 with B&M Lockup
Axle/Gears: Moser 28-spline axle; 3.23 gears
In the next year or so I plan to swap my 305 for a 350. The rear 2-pc seal is leaking in the 305, but I've always thought when I pulled it to replace that seal...I'd replace it. Remembering that I don't have to worry about emissions...I have no computer...I saw this in the paper...what do you think? Just need heads & more details on the cam, right?
chevy 350 block, 4 bolt main, 3970010 casting, 60 over, fresh from machine shop, comes w/speed pro, cast flat top piston & rinngs...$600.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Is this 350 a good deal?
Is it an assembled short block, or just a block with pistons and rings?
Engine: 350 4bbl.
It sold...but yes, it was put together. Fair deal I suppose, just wanted someone to second me on it. Back to the search.
Thanks!!
Thanks!!
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Too much! 60 over is about the limit, so it's seen it's best life already - no room for future rebuild. 350's are too bountiful to not be a little more picky.
hectre13
Dec 11, 2023 08:14 AM
NinjaNife
Aug 23, 2015 11:49 AM
