Accessories swap from 305 TBI to 383 Carb
Old Jan 22, 2008 | 04:03 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I am almost finished building my shortblock 383. I am now making plans on what parts I am going to need. I have a 305 TBI currently running in my car and everything is working. I would like to keep a serpentine belt setup. I plan on getting heads with accessory holes. Would it be possible to use my accessories from the 305 TBI (except smog and AIR) to the 383 carb?
INFO:
My 305 is an 88 TBI
The 350 block i used is a pre 87 block.
I am using a double roller timing chain, will this get in the way?
I plan to keep A/C and Power steering.
My waterpump on the 305 is new. Will this waterpump work with the pre 87 block?
Are the accessory holes on the aluminum heads i plan to use the same as the accessory holes in the original cast heads?
I plan to have a little above 400h.p.
Does anyone know if this will work or a way that it is possible to make it work?
Thanks,
Dennis
Old Jan 22, 2008 | 04:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Accessories swap from 305 TBI to 383 Carb
Everything is exactly the same.
Old Jan 22, 2008 | 06:13 PM
Engine: 388 Carb
Axle/Gears: 4.10
Thank you very much, That is what i was thinking and hoping, but thank you for reassuring me.
What do you suggest with the debate over dropping the tank and putting in a sump versus just getting an AFPR???
I have searched and read other posts on this topic, but it seems to be a 50/50 split on what to do...
Old Jan 22, 2008 | 06:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I've always considered a pusher electric back by the tank to a mechanical on the engine to be the premier set-up. You should use a return-style regulator after the mechanical pump and before the carb.
Old Jan 22, 2008 | 06:19 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Old Jan 22, 2008 | 07:08 PM
Engine: 388 Carb
Axle/Gears: 4.10
Can you help by explaining that a little better. I thought that I had two options.
1) Swap the pump that is in my tank with a sump setup from a carbed vehicle and run a mechanical pump from the engine.
or 2) Keep the working pump that is in my tank and put a return style FRP to lower the fuel pressure to 5-6 psi as opposed to the double digit numbers that the pump is pushing now.
What are you suggesting?
Old Jan 22, 2008 | 07:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You can also use a return-style mechanical pump in conjunction with the in-tank pump. The regulator in the mechanical pump will still regulate down to 6-7 PSI and the return line will keep the in-tank pump from burning up. The in-tank pump will preempt any vapour-lock issues, and you won't have to drop the tank to remove the pump and install a new pickup. Best of all, a mechanical pump is about $25 instead of about $75 for the regulator. Add on $15 for a fuel pump pushrod and $7 for a mounting plate and it's still a pretty good deal.
The only cases where that wouldn't work would be if your block didn't have the fuel pump mounting provisions, or if your cam didn't have a fuel pump lobe.
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
92purpz28
Aug 11, 2015 02:30 PM
tero
Aug 6, 2015 06:34 PM
