Question on oil pan for big block.
Old Jan 31, 2008 | 12:23 AM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
For those of you who have swapped a big block into a thirdgen, What oil pan did you use? I used a stock big block pan the first time but want one with more capacity this time around. Thanks!
Old Jan 31, 2008 | 12:40 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Question on oil pan for big block.
I use a standard Moroso 7 quart pan. You'll also need the longer oil pump pickup for this pan.
http://www.jegs.com/webapp/wcs/store...10002_21056_-1
Old Jan 31, 2008 | 08:04 AM
Car: 86 z28
Thanks for quick response Stephen.
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
