Budget 350 build dyno results
Transmission: 4L80E/4L80E
Engine dyno, I presume?
You gave no details except what's in your sig.
Car: 1987 Z28
Engine: 355
Re: Budget 350 build dyno results
i duilt it on a 2000 dollar budget. Most of the parts are either used or i got off ebay or hunted around for good deals. The heads and the pistons were the only new items and they cost me the most. its making about 9.8 compression and the cam has like a 110 lsa. ill show picutres of the completed engine in a couple of days.
Not too bad...
Best thing is, there's a little left in it, judging by the A/F ratio column. Get that closer to 12.8:1 or so, you'll probably pick up a bit more.
What heads? What cam?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Huh, Pro Comp aluminum heads, SRP forged pistons, and you call that a budget build? Damn. You must know a guy who knows a guy to get all that built for $2000. $2000 for just the heads and pistons sounds pretty accurate, but machine work, intake carb etc etc etc... You got a deal on that.
Speaking of.... induction on this? Exhaust?
Car: 1987 Z28
Engine: 355
yeah ur right i spent more like 2500 but i got the engine for free and it was already machined and had most of the parts.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
more detailed specs would be nice. looks good tho, seems like a nice mild street setup, puts out similar power to a ZZ4 crate
LT1Formula
20
Nov 14, 2015 12:02 AM
