383 swap complete, need help w/fuel pressure
Old Feb 16, 2008 | 05:12 PM
keo1986TA's Avatar
Hey everyone,
I am new to the forum but my buddy recommended this site for great help.
I recently completed swapping out my old 305 with a blown piston for a brand new 383 stoker motor. I have about 150 miles so far max on the new motor and I can not get the fuel pressure under control. Last time I checked it was at about 60 psi. The shop that did the work for me changed the regulator out for me, and yes i upgraded the injectors also. I had them put in accel 24lb injectors. So here is the question.
1) How do I get this fuel pressure under control? the screw on the adj. regulator does nothing. Is it possible the shop installed the regulator wrong?
2) Secondly, will I harm the engine or anything else by driving with too much fuel pressure? It is just a bitch to start when hot, cold starting is no problem.
I am so close to having this car ready to run and your help would be much appreciated.
Thanks,
Chris
p.s. sorry for the lack of background info, I am on the road right now and will be home later on tonight. If any additional info is needed to help me out let me know and I will reply.
Old Feb 16, 2008 | 05:33 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: 383 swap complete, need help w/fuel pressure
High pressure can be bad on the injectors.
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
