TBI to TPI now no injector pulse HELP!!!!
Old Mar 1, 2008 | 07:14 PM
jonarotz's Avatar
Car: 91 Z28
I pulled out my TPI 305 from my 91 Z28 and transplanted it into an S10. The S10 was originaly TBI so I followed the TBI-TPI swap tech article. I swapped it over to a 730 ecm and I am using the same memcal I had in the Z. I am good at wiring and I took my time changing pins. I even double checked every pin after I swapped. It is all hooked up now and all I get out of it is spark, no fuel injector pulse. When I check the voltage at each injector plug I get battery voltage on both sides when the key is on. I have disabled VATS in the chip so that is not an issue, I have checked all the fuses and they are good, grounds look cool too. I manually gounded the injectors and the thing ran. I am out of ideas. Maybe someone here is thinking of something I am not.
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Sanjay
Aug 12, 2015 03:41 PM
