need help with engine swap
Old Mar 4, 2008 | 03:59 PM
ckyfreak2010's Avatar
i have a 92 v6 RS automatic...i was thinking about dropping in an LS2 but gas prices are a little high now...so i thought about dropping in a V6 from a 96-02 camaro they have 200 hp and about 30 mpg....would this swap be worth it or would there be a ton of work to be done.....
thanks
Old Mar 4, 2008 | 05:34 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: need help with engine swap
It's easiest to combine your terms to, "it would be worth it AND there would be a ton of work to be done!"
We talk about the pros and cons of this in the V6 section often. You should search over there...
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
