I4 motor mount question
Old Mar 24, 2008 | 11:37 PM
badinfluenceRS's Avatar
Car: 1994 Trans Am - 1992 Firebird
Engine: LT1 5.7 V8 - 3.1 V6
Axle/Gears: 3.42 / LSD
does anyone know if '82 4cyl motor mounts are unique, V6 or V8 compatatble?
Old Mar 28, 2008 | 08:09 PM
Re: I4 motor mount question
bump
Old Mar 31, 2008 | 07:22 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Unique to the I4
Old Mar 31, 2008 | 08:08 PM
are there any other engines that will use the mount locations that are currently in the car?
Old Apr 1, 2008 | 08:22 AM
All engines use the same mount "locations". They just use different "stands" bolted to the K-member. All cars are the same there.
Old Apr 1, 2008 | 09:39 AM
will any other engines bolt in the car with its current "stands"?
Old Apr 1, 2008 | 11:55 AM
I doubt it.... that's why they make different "stands" in the first place, is to fit different size/shape engines, which that one is pretty "different".... but as far as any kind of specific details about those 4-cyls, I haven't the vaguest foggiest clue. When you're getting rid of it, just get the right "stands" for whatever more sensible motor you're putting in its place.
Old Apr 1, 2008 | 03:53 PM
so if i say go with a olds 455, i would need the stands from whatever vehicle the 455 was from?
then drill if need to bolt them in the fbody crossmemeber
Old Apr 1, 2008 | 04:38 PM
That would be logical...
What people usually do, is bolt up the motor, trans, mounts, crossmember, and all that; lower the motor down into the chassis, with the rear of the trans mounted where it needs to be; mark the frame; and drill for the frame side of the mounts.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
redmaroz
Aug 16, 2015 11:40 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
