new motor, no heater. need help
Old Mar 26, 2008 | 03:25 PM
90rs350crate's Avatar
Car: 90 rs
Engine: 330 hp crate 350
Transmission: stock
ok so there are two problems first:
it's stuck in defrost and I've read a couple of threads that say that this is the defualt position and that must be a vacuum line disconnected somewhere. is there any other way for it to be stuck in defrost because i'm pretty sure i connected all the vacuum lines but maybe not i suppose.
secondly, I only get cold air. I have the lever all the way up and no hot air. is this also a vacuum problem or is it something else. also I removed that plastic junction deal that had a heater hose from the firewall and a line off of the lower line that runs to the radiator, it also had a vacuum line running to that junction that i ran to a another vacuum line. what does that plastic deally bobber do anyway? must be some type of connuter valve, i dunno.
any help is much appreciated
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
