350 swap mpg????
Old Mar 30, 2008 | 02:44 PM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
350 swap mpg????
I am putting the 350 in my car soon and am kind of worried about my gas mileage since i have been hearing gas is going up to 4.50 this summer. The engine will have lunati voodoo cam (.468/.489 lift) ported and polished 305 heads(the 416's) with 3 angle valve job. performer intake, edelbrock 650 carb, and full exhaust. what could I expect to get for mileage driving conservatively?
Old Mar 30, 2008 | 02:51 PM
Rva's Avatar
Rva
Car: 1984 z28 camaro
Re: 350 swap mpg????
my car is a 305 and it already gets shitty gas mileage so im guess it wont be any better...
Old Mar 30, 2008 | 03:34 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
In theory gas usage has a lot more to do with how much power you're making than displacement.
I you use a similar cam to what you have, then your gas mileage should stay very similar.
Old Mar 30, 2008 | 03:39 PM
malcom2073's Avatar
Car: 1987 IROC-Z
Engine: 383ci SBC
I had a VERY similar setup in a car with 4.11 gears in the rear and was getting between 7-10mpg with general around-the-town drivin, but it was only a 3 speed, no overdrive so you might get more with an OD.
Old Mar 30, 2008 | 03:56 PM
brodysZ28's Avatar
Engine: 383
i just have the t5 with stock gears. so i should get quite a bit better then 10 right?
Old Mar 30, 2008 | 04:00 PM
malcom2073's Avatar
Car: 1987 IROC-Z
Engine: 383ci SBC
iirc, I was getting 15mpg average with 2.73's and a 3 speed. Carburators arent the best thing for gas mileage.
Old Mar 30, 2008 | 04:32 PM
brodysZ28's Avatar
Engine: 383
also i dont live in a city so its lk 45mph on average with few stops and i just leave it in 5th. so my mileage might be a little better. idk, hopefully 13 or so.
Old Mar 30, 2008 | 07:08 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
45mph and the 3.73s in the car it will be crappy because you'll be lugging the motor. If you're concerned about fuel milage, ditch the 305 and 5-speed, put out the money and get an LSx series motor (5.3, 5.7) and a 6-speed and you'll probably almost triple the milage (an LS1 putting 500 at the wheels can still get 30mpg with a 6-speed and 3.73 gears.)
Old Mar 30, 2008 | 07:11 PM
skinny z's Avatar
20 mpg hiway.
350 with Vortec heads and a 218@050 cam.
700R4 and 3.73:1 rear gears.
Old Mar 31, 2008 | 08:33 AM
brodysZ28's Avatar
Engine: 383
what do these cars have for stock gears again? what is the best thing to do for gas mileage?
Old Mar 31, 2008 | 09:13 AM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
stock gears i believe were starting at 2.73 then 3.08 and then up to 3.42. You can check RPO codes to see what gears you have. Best thing for gas millage probably 2.73 but if you get 6 speed 3.73 would work good.
Also about millage:
Originally Posted by 1bad91Z
Over the last few months, I've been averaging close to 19 MPG in the city with the red Z. I just finished the first full tank of gas after installing a MSD Blaster GM coil and a set of March performance billet underdrive pullies (crank and alternator). I just averaged 20.73 MPG in the city and that was even stepping on the gas (having fun) half of the time!! I might be able to squeeze a little more if I baby the car for the duration of the whole tank! Oh, and the adder power was a noticable difference too!...
...the motor in the red Z makes atleast 360 HP at the flywheel...
But being a carbed motor you probably can get 15 mpg with a tune
Old Mar 31, 2008 | 09:57 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Ditch the Edelbrock carb. Bad idea, both for performance and economy. Total waste of performance $'s.
Keep the stock carb. I typically get 18-20 combined MPG. It'll do better sustained highway, but it doesn't see much of that.
The only excuse for a different carb is manual tranny. Even then, the Edelbrock is the wrong choice - either double pumper, or keep the stock q-jet. If economy is a concern, the q-jet wins again.
Old Mar 31, 2008 | 10:47 AM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Like 5-7 said, a double pumper will slaughter your gas mileage. This I know, as I've got one on my engine. I couldn't imagine daily driving my car. I use premium gas. I would run out of money.
Old Apr 3, 2008 | 09:59 PM
stevo the torpe's Avatar
Car: 91 maro
Axle/Gears: 373 locker
i began with a 305 tbi got 22 miles to gallon easy on gas stock.put gears stall built trans.19 maybe put a stock 350 under stock tbi with headers better gas mileage like 20.put 383 with all goodies and carb 10 foot in it or not horrible on gas.but very fast lol
Old Apr 4, 2008 | 12:10 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you're worried about gas mileage you shouldnt be modifying your car with a bigger engine and more power. Sorry to be harsh.
I just dont care about it. Forget MPG, I want my MPH! For the record, I get 25+ miles per gallon on the highway, and about 15 in the city. But I have fuel injection, and I tune the computer myself.
Old Apr 4, 2008 | 08:00 AM
brodysZ28's Avatar
Engine: 383
yea, i would rather have a fast car then get 30 mpg, bein able to smoke all my friends with 4 cylinders makes it all worth while... but bad gas mileage does suck. lol
bellez77
Sep 5, 2015 08:39 PM
InfinityShade
Aug 22, 2015 08:00 PM
theshackle
Aug 22, 2015 06:52 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
