327 starter issues
Old Mar 30, 2008 | 05:14 PM
hayabusa1257's Avatar
Car: 86 ta
Engine: 333
Axle/Gears: stock
327 starter issues
Hi i recently swapped my 67 327 into my 1986 ta orginally 4 barrell 305 vin h. I mounted the starter off of the 305. Using the 305 flywheel, so i can use the 305 starter. I'm having problems wiring the starter. I have the big leed out of the postive battery on the main starter terminal. Which I know is right, but i have two more little wires, one which is one with a 20 fuse link and two into one with a 16 fuse link. I know the other day i put the single on the terminal closeest to the engine and i got power but no crank. But today with it the same way i had nothing but i did have some blown fuses, so thats probly why I had no power whatsoever. Nothing. Does anyone knopw this wiring it's driving me nuts
Old Mar 30, 2008 | 05:30 PM
Car: 86 ta
Engine: 333
Axle/Gears: stock
Re: 327 starter issues
After reading some forums here's what i think i should put all my red wires and the black wire on the big post and run the purple wire that was cut off to the termianl
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
greenyone
Sep 2, 2015 03:39 PM
destroyerwes
Aug 26, 2015 08:17 PM
86Base
Aug 8, 2015 01:34 PM
