motor mount question
Old Apr 7, 2008 | 10:12 AM
andrew5546's Avatar
ok im doing a v6 to v8 swap and i know i can just get lower motor mounts from any 3rd gen v8 fbody and bolt them to the holes further up on the k-member. but the problem is that my v8 is from 1966 and it has a different style of motor mount for the ones that bolt to the block. does anyone know of any quick solutions or adapter kits to make this work?
Old Apr 7, 2008 | 02:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No adapter kits.
But, there are guys who have the mounts you need available.
Like me.
I've been waiting for someone to say they need them.
Old Apr 7, 2008 | 10:11 PM
andrew5546's Avatar
Re: motor mount question
Originally Posted by five7kid
No adapter kits.
Like me.
you are my hero!
Old Apr 7, 2008 | 10:37 PM
five7kid's Avatar
What transmission are you going to use?
Old Apr 8, 2008 | 08:49 AM
andrew5546's Avatar
Im trying to find a 700r4 with the right bolt pattern right now why?
Old Apr 8, 2008 | 09:08 AM
five7kid's Avatar
If you were considering a TH350, I have a crossmember and driveshaft you could use as well.
Old Apr 9, 2008 | 08:33 PM
five7kid's Avatar
What heads are you going to use? 1966 heads won't have the accessory bolt holes on the ends.
Old Apr 9, 2008 | 11:34 PM
andrew5546's Avatar
no they dont have the accessory holes. but im running manual steering and no AC so its ok
Old Apr 9, 2008 | 11:49 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yes but you also need one hole in the pass side head end for the alternator pivot bolt
you can drill and tap the 3/8" hole though
also a 66 block is no different than any other block
in that the mount bracket holes pattern is the same
different style in 66 yes but same bolt pattern
no issue here at all
also, these 55-60's heads didnt always have no holes, only typically fuelie and power packs didnt, but regular passenger/truck(lower HP) ones did, almost always
are some common misconceptions here i see
Old Apr 10, 2008 | 04:46 PM
andrew5546's Avatar
hmm i think i might already have a hole somewhere for that alternator pivot, ill look for it next time i get to it. it has to have a provision for an alternator somewhere, the guy i bought it from just took it out of his truck and he sold me and alternator and some brackets with it.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
redmaroz
Aug 16, 2015 11:40 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
