tranny ?
Old Apr 14, 2008 | 08:52 PM
86V8Z28Camaro's Avatar
Car: 86' Z28 Camaro
Engine: 350 holly 650cfm carb
Axle/Gears: 3:73 posi
tranny ?
i just put a 350 in my camaro and i still got the stock 700r4 installed.not changing ut yet.is the tranny going to blow o somthin o will it be fine for now
Old Apr 14, 2008 | 08:56 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: tranny ?
depends how many miles are on it.
it should be fine though, its not just going to blow cause of the larger motor
Old Apr 14, 2008 | 08:58 PM
Car: 86' Z28 Camaro
Re: tranny ?
arond 150 but its fine shifts fine and eveythin
Old Apr 23, 2008 | 12:17 PM
sngreen's Avatar
Car: 1984 Z28
Engine: 468 Ci
Transmission: T-5 (Until it breaks)
Axle/Gears: 3.73 posi
Re: tranny ?
the real bad thing about the 700r4 is that it has small clutch packs, and with smaller clutch packs things breakdow quicker, expecialy when the trans has been abused, but you said it still shifted fine, so if your concerned about it put another aux. trans cooler on the car the cooler you keep it the longer it will last!
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
