305 TBI to TPI
Old Apr 24, 2008 | 09:26 PM
gtpro700's Avatar
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
305 TBI to TPI
A buddy of mine has a KITT car in which he added a ton of weight by doing so and also has a lot of stereo equipment in it because he brings it to sound competetions. It is a 1990 firebird formula with a 305 TBI he doesnt want to make the thing a fast car by any means he just want it to get out of its own way. I have a TPI system from my 305 I took out of my car a while ago. Would there be any problems with converting his TBI to TPI to get that torque that TPI's make? Would it be worth it? how much is there to gain with this swap? He is also lookign at putting the larger aftermarket runners on for extra gains as well. Will my wire harness and computer from my TPI connect up easily with no probelms? Thanks for all the help guys.
Old Apr 24, 2008 | 11:55 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 305 TBI to TPI
Please read the tech article about swapping from TBI to TPI, and then read the many topics that cover this swap from people who did it before you. You'll find 99% of your questions already answered in those threads. Good luck with the swap and enjoy the new found power!
Old Apr 25, 2008 | 12:16 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: 305 TBI to TPI
TBI and TPI both suck.... First and for most your mixing 2 things together that really suck the TBI has shitty cam and heads to begain with and TPI heads arent much better.... TPI has a long runner! just try sucking in air why your already underwater doesn't work to well.... basically you'll be going more backwards then forwards then anything
Old Apr 25, 2008 | 01:52 AM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
Re: 305 TBI to TPI
If you have the stuff I would change in in a heart beat. Fueledsoul may be right in saying TBI heads are crap BUT TPI is better than TBI any day of the week. My 89 RS was TBI and I changed it over to TPI and it was a lot more fun to play with.
If you have the ecm, wiring harness and intake, the only other thing would be a fuel pump because TPI takes more fuel pressure than TBI. I took everything from a wrecked TPI car and plugged right up to my RS car.
Glowsock
Jul 24, 2025 03:15 PM
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
92purpz28
Aug 11, 2015 02:30 PM
