TPI swap wont start...
Old May 5, 2008 | 05:53 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
I have a 91 RS that I swapped an 87 305 TPI into and it wont start. I swapped over the engine and dash harness so I wouldnt have to mess with pinouts. I do not have all my sensors hooked up but I dont think that is my issue. Are any of the sensors essential to the car starting? Also while it is cranking over I get smoke from the negative battery cable. Help!
Old May 5, 2008 | 06:12 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
Re: TPI swap wont start...
ok I just tightend down the negative cable and its not smoking anymore but now the positive terminal on the battery is hot is that because its not tight?
Old May 5, 2008 | 07:45 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Possibly.
What sensors do you not have hooked up?That could be the reason it won't start.
Old May 5, 2008 | 08:14 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
the knock sensor, temp sensor (on the driver side head), oil pressure (by the oil filter) are not hooked up cause they are broken.
Old May 5, 2008 | 09:40 PM
I'm pretty sure the knock sensor and oil pressure sensor need to be hooked up,the temp sensor on the drivers side head I believe just sends info to the gauge itself and shouldn't effect the ecm
also,is this a complete engine swap or just the tpi swap?
If you swapped tpi intake onto a tbi engine,you got the wrong knock sensor on there.
Old May 5, 2008 | 09:52 PM
Egg83's Avatar
Car: 85 Firebird
Engine: 355 Vortec TPI
Transmission: 700r4 with Pro-Built goodies
Axle/Gears: LS1 3.42 Posi Disc
Black Ice, You need to hook up the oil pressure switch (the one near the filter). If this switch is not hooked up your fuel pump will not run. It will only prime when you initially turn the key. That is unless you have it wired up differently. -Bob
Old May 5, 2008 | 10:06 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
TIMMYS89GTA- This is a comlete motor swap out of a running 87 Iroc all wiring also came from the iroc
Egg83- It is not wired differently however I still do not hear my fuel pump at all when I turn the key
I will try to get the knock sensor and oil pressure sensors hooked up and see if it helps any
Old May 5, 2008 | 10:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You obviously have a problem with the fuel pump circuit. I can't spout details, but the oil pressure switch is not the primary circuit, the fuel pump relay is.
Old May 5, 2008 | 11:07 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
five7kid- I also have no spark at my plug wires leading me to belive that the problem is bigger than just the fuel system
Is it possible that somthing in the body wiring that had to be adapted from 91 to 87 stuff is causing my issue?
Old May 5, 2008 | 11:52 PM
five7kid's Avatar
Sure sounds like it. Again, I can't provide details, but such problems sound familiar.
Old May 6, 2008 | 09:59 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You should never try to go backwards with electical. An '87 uses two wire harnesses, the '91 has everything in one. That's under the hood anyway.
Old May 6, 2008 | 10:28 AM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
dyno don- Not sure what you mean by 87 having two harnesses under the hood? I pulled 1 out of my 91 under the hood and pulled 1 out of my 87 under the hood. The only challenge in the wiring swap was adapting the 87 dash harness to the rest of the 91 body wiring (lights-gauges-ect.)
Old May 6, 2008 | 11:28 AM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
Woo-Hoo! It lives! I just had the two pigtail conectors by the battery backwards. Thanx for all your advice guys im sure I will be needing more in the near future...
Now off to get those sensors lol
Old May 6, 2008 | 09:58 PM
Lisa's Avatar
Axle/Gears: 323
good luck with it!
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
