Harness madness!
Old May 8, 2008 | 09:57 PM
thesargster4's Avatar
Car: 1986 WS6 TransAm
Engine: THREEFIDDY!
Harness madness!
Swapping a L98 TPI into my 1989 Rs maro.. Has a built T5 trans.
Im getting ahold of three things-
85' Engine harness
85' 305 ECU w/ 350 PROM
(possibly) 87' Dash harness
(all from irocs or z's)
Should this have me set harness/ecu wise? Or am i ganna have problems..
If the 85' engine harness is from a 700r4 car, will it make a difference sense i got a T5?
P.s.. can i just use my same V6 dash harness if i dont get ahold of the 87' dash harness?
Old May 8, 2008 | 10:03 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
Re: Harness madness!
why do you want a ecu and harness from a 85? it was a one year only unit, and kinda a "dumb" unit. i would look for somthing from a 87-89
Old May 8, 2008 | 10:04 PM
Engine: THREEFIDDY!
Man i wish i knew all that crap.. first time doing an efi swap heh
Old May 8, 2008 | 10:08 PM
if you do go with the 85 stuff, i have a jet chip if your interested pm me.
Engine: THREEFIDDY!
Well now that i know that... Can i use the same dash harness?
John
Old May 8, 2008 | 10:09 PM
that i dont know. sorry
Old May 8, 2008 | 10:10 PM
Engine: THREEFIDDY!
pm sen
Old May 8, 2008 | 10:24 PM
Engine: THREEFIDDY!
Found a prom and brain on ebay for a 87-89.
Will the 85 harness work on a 87-89 ecm?
Also.. to anyone that knows if i can use my same dash harness let me know.
John
rs_z28_vert
Sep 30, 2015 09:47 PM
z28joe2
Sep 28, 2015 05:54 PM
Eric-86sc
Sep 28, 2015 11:37 AM
tattmann
Sep 27, 2015 05:20 PM
efiguy
Sep 27, 2015 01:30 PM
