305tpi to a 350 4 bolt main Can I use my tpi?
Car: 91 camaro vert
Engine: 350,113heads,ccxfi260, slp shortys
Axle/Gears: 3.23s posi discs
I have 91 z28 vert 305 with a 700r4 and I found what looks like a good deal for a 350 4 bolt main bored over .30 new pistons,piston rings camshaft and rockers freshly built.Its from a 88 gmc truck was wondering if It is tpi compatible I will use my system off my current car untill I can get the aftermarket stuff. Or is it better to keep it carb right now I'm low on money right now and just want a big motor in my car for the summer commin around.My car is high milage and the 305 just isn't puttin out good power I think the trans is the reason for that.Looking for any kind of advice I'm young and new at this first car.
Car: 1986 WS6 TransAm
Engine: THREEFIDDY!
Re: 305tpi to a 350 4 bolt main Can I use my tpi?
The TPI Base plate will bolt up to the heads if its from an 88.. 87-92 GM used the same bolt patern on there intake mani's. Just be sure you get a PROM for your ECM from a SD 350 car, and a 350 knock sensor. I would think about getting yourself a pair of 24# injectors to make it all right.
John
John
Transmission: 4L80E/4L80E
A couple of corrections are in order:
- Overbore would be .030", not .30"
- 350's had 22 lb injectors, not 24 (no need for 24 on a stock engine)
A couple of points:
- Your 305 heads would be better performing than the '88 truck 350 heads (although not a lot on an otherwise stock engine)
- You will need to use the tailshaft housing off of your current transmission in order to use the truck TH700 (assuming it's a 2WD tranny)
And a question:
- Keep what carb?
A couple of points:
And a question:
- Keep what carb?
Car: 91 camaro vert
My mistake I was under the impression it was a carb engine but it is fuel injected. I will be using my camaro headers, as far as changing the injectors is it better to put higher flowing injectors now before it goes in even though its gonna be running stock for a lil while.Thanks for the advice and tips really appreciate it. I feel so lucky that it's a 88 engine and is not angled the same way as the older ones.What other parts will I have to change to get this engine in i heard maybe the steering pump will need to be changed.
Car: 91 camaro vert
Do I need to get this knock sensor from original engine or just buy one from a autoparts store. I think I am better off using the heads on the 350 engine they have been redone.I wasn't sure that I would be able to use these parts you guys really helped me out a lot now I can get some serious power outta my car.
Engine: THREEFIDDY!
There $30 at autozone. Pick one up for an 88' Iroc with an L98. If the 350s heads were machined, use them.
Not to burst your bubble, but there is more power potential in the 305 heads than there is in those 350 truck heads.
You'll probably make more power than the 305 had, but you'll be far from "serious" power.
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Sanjay
Aug 12, 2015 03:41 PM
