LT1 heads, cam, intake swap on a '90 305
Old Jun 14, 2008 | 07:45 PM
305 JUMPOFF's Avatar
Car: '90 Camaro RS
Engine: L03 TBI
Transmission: TH700R4
Axle/Gears: 3.42 open diff
I have a 1990 Camaro RS with a 305 TBIand a 700R4. I want to swap in an LT1 intake, heads, and cam on it. Also I may put headers on it. I know my motor comes from the factory with about 170 pathetic hp. How much HP can I expect to gain? What would be a good 1/4 mile time for that?
Old Jun 14, 2008 | 08:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I would expect about half the HP gain the money it would cost you would give if spent on an LT1 swap.
Going through all of the modifications and expense to put LT1 heads & intake on a Gen I SBC never made sense to me, and doing it on a 305 makes even less.
Old Jun 14, 2008 | 08:11 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: LT1 heads, cam, intake swap on a '90 305
The only thing directly swappable is the LT1 cam. The heads and the intake require extensive modification to work with a standard SBC engine.
You can find out more info about the LT1 intake here: http://www.lt1intake.com/
For the LT1 camshaft swap, see the TBI board, as its been discussed numerous times.
Old Jun 14, 2008 | 09:38 PM
Car: '90 Camaro RS
Engine: L03 TBI
thanks for the help. There would still be mods to the car to swap in an entire LT1 engine, so either way, I would be spending more money than planned. I find it less expensive to swap the parts than the complete motor.
to kevin91Z, I've heard about the intake swap and whats involved and Im intersted in doing that. My question is whats involved in making the heads work with the SBC? thanks again for your help
Old Jun 14, 2008 | 10:22 PM
87rock's Avatar
The head swap would not be worth it, way more money and effort than gain. If you want a better flowing head, buy a small aluminum like a 180cc or find a decent flowing set up iron 350 heads, they will flow as much air as your 305 will ever use. Swapping a 350 in is the better choice but good luck either way.
Old Jun 14, 2008 | 10:45 PM
five7kid's Avatar
The entire LT1 swap would cost less than modifying the parts to fit a Gen I SBC.
Frozer!!!
Jan 19, 2024 04:55 PM
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
st.evel07
Aug 13, 2015 06:15 PM
