i want to delete the in the tank pump
Old Jul 2, 2008 | 09:23 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
hey guys im building a turbo 89 camaro. i want to run the stock tank. im having a sump installed so i can run -12 and line. but i want to run the return on the top where the stock lines are.
does anyone make a return system that comes with the plate and ring to get rid of the in the tank pump but keep the sender for the fuel level?
i need to run a -10 return thanks .
Old Jul 3, 2008 | 12:36 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
No known kit. I can't imagine it would be any harder to fabricate than sumping the tank.
Old Jul 4, 2008 | 06:22 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
Re: i want to delete the in the tank pump
my only big worrie is having enough clearance for a 1/2 weld in bung
or a -10 bung and a 90 deg hose end between the top of the tank and the body.
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
