Swapping 86 Z-28 305 carb.For an 87 TPI!
I have already got a good start(Got 305 out, and ready to install TPI)I have the full engine harness,and i cut fuel pump & sending unit harnass out as close to the fuse block as possible!Is there any specific place to hook up the fuel pump wire in the fuse block since this was a carb car?I'm also switching tanks for the 87 one has a baffle!are there any other things i need to know?Also I have eliminated Smog set up, is there any one who reburns chips to take that out of the loop?Thanks,
Ed
Ed
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
The fusebox has a slot for the fuel pump.
I don't know what "smog set up" you've deleted, but your best bet is to learn PROM burning for yourself. There's a forum dedicated to the topic.
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
