'89 350 Truck block - am I missing something here (with pics)
Old Jul 28, 2008 | 11:21 PM
RedOctober's Avatar
Car: '88 Sport Coupe - 383 Stroker
Howdy, folks!
I have an 1988 Camaro Coupe that originally had a 305. I'm swapping in a 383 and going to carb.
My engine is almost all done, but I just notice a possible clearance issue:
I've been building this engine up for a while now, and I started by buying an engine block from a local machine shop. The new 350 engine block (coded TPK, and seems to come from a 1989 truck) has the motor mounts all the way towards the from of the block.
By my measurements, it doesn't look like this engine will fit on the stock V8 motor mounts - it ends up being mounted too far to the back of the engine compartment (less than 0" of clearance between the back of the block and the firewall).
Am I missing something, or is this a common setup that would require different motor mounts? I swear - I searched around the threads here and other places, and all I see are references to LSX engine swaps...
Thanks in advance for the advice!
Attached Thumbnails '89 350 Truck block - am I missing something here (with pics)-dscf0015-medium-.jpg   '89 350 Truck block - am I missing something here (with pics)-dscf0016-medium-.jpg
Old Jul 28, 2008 | 11:24 PM
RedOctober's Avatar
Re: '89 350 Truck block - am I missing something here (with pics)
DOH!!!
Is something like this my answer, or is it more like this?
Old Jul 29, 2008 | 12:29 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Looks like standard Chev V8 mounting. BBC and SBC V8 engines share the same engine mount locations measured from the bellhousing. The mounting bosses on the side of the blocks are all in the same position for all the gen I SBC. The motor mounts on your 305, 350 or a 400 block will be the same distance away from the bellhousing. How much of the motor sits forward of the mounts doesn't matter but all the SBC blocks have the same external dimensions. The engine will sit right back to the firewall.
Those adapter plates in the first link are to install a Gen I SBC into a car that originally came with an LS1 engine. The second link is adapter plates to put a V8 into an S10.
Old Jul 29, 2008 | 12:57 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Other way around, actually (Summit's description is weird). You can put an LS1 engine in with stock mounts with them. Except can't use f-body LS1 AC compressor.
Anyway, yes, your engine has stock SBC mounts.
Old Jul 30, 2008 | 01:40 PM
bigzeke's Avatar
that engine will sit just fine in that car with plenty of clearance use the forward most mounting holes ------------------bigzeke355bird92
Old Jul 30, 2008 | 02:02 PM
jpeden31's Avatar
Car: 1984 z-28
Engine: 305H.O. L69
Axle/Gears: 3.73 G80 GT4
gen 1 into a car that came with a gen 1
dont worry, it might look big but slide it on in there and you'll be happy
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
mhatfield 14
Oct 24, 2015 07:48 AM
camaro71633
Sep 1, 2015 10:24 AM
BBSDesigns
Aug 11, 2015 07:39 PM
