need new engine 355 or 383??
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
On friday 22nd when i went to the dragstrip i raced my 89trans am and managed to get a 13.4 with the new modified LT1 manifold but apparently my block could not handle the power that the lt1 had to offer so it started smokin alot.
Im debation on whether i should go with a 383 or a 355, my current setup is a stock bore 350 4bolt, flat tops and some 64cc ported truck heads and as stated above the lt1 intake and some summit shorties, 24# injectors, hi-pressure fuel pump and still rocking the MAF, and a cam with a duration of 212 and 218 and a lift of about ~.488 + 1.6 rocker arms.
My main concern right now is the bottom end i know my heads will not be able to handle any well built engine but i cant afford to go all out right now. My goal is to go mid to low 12s. Can you guys help me out with this build and inform me of whats good and whats not. As i said before i am unsure of which route i wanna take as far as displacement.
Thanks in advance
Thanks in advance
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: need new engine 355 or 383??
It depends which parts you can reuse out of the 350. If you have to replace the rotating assembly, build a 383. If you can reuse it, build a 350.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
wel ive decided to go with a 383, i was looking at the kits on summit for like 770 balanced with pistons +5cc 5.7 i-beam rods, 3.750 crank, rings bearings, harmonic balancer and flexplate.
are these kits any good i think its by either eagle or scat??
and
would it be any better to go with 6"rods??
when will my stock MAF max out??
and
Engine: 383 Carb
Transmission: 4L60
Eagle and Scat are both fine. The 5.7" rod stuff is more common and therefore usually cheaper. For a street engine, there's no additional benefit to a 6" rod to justify the extra cost.
ha awsome thanks for the reply!!!
i am looking to buy the eagle kit # B13405L03053
now my questions are,
it says piston +5cc but no actual estimate on comp. ration, what do you think it would be w/ 64cc heads??
also this is a noob question but what does it mean by decking the block?? thanks again
Car: Camaro
Engine: Carbed L98
Transmission: TH350
If you are going for 500hp or more, go with a H-beam rod.
Here are a few more places to check. Some have in house brands that are good quality.
http://www.speedwaymotors.com/
www.strokermotor.com
http://www.ohiocrank.com/index.html
www.flatlanderracing.com
www.cnc-motorsports.com
Engine: 383 Carb
Transmission: 4L60
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I have seen I-beams twisted into a S shape many times. I have seen H-beams sticking out of the side of the block and you could literally reuse them.
Some of the sites I posted have H-beams for the same price of I-beams if not less. Im assuming that the I-beams he was looking at were maybe 5140.
Engine: 383 Carb
Transmission: 4L60
The shape alone doesn't give the rod magical qualities. A good rod is a good rod, and a cheap rod is a cheap rod. Shape is almost just a matter of preference these days.
Car: 87 IROC
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
