Finally it is happening (305-502, auto- manual, drum-disc swaps...)
Old Nov 20, 2009 | 10:54 AM
  #101
engongam's Avatar
Car: 1991 Trans Am GTA
Engine: 502 Ram Jet
Transmission: TKO600-racing gears
Axle/Gears: 12 Bolt Moser-33"axles-3.91 ratio
Re: Finally it is happening (305-502, auto- manual, drum-disc swaps...)
Hello, I started to work on my interior, I re painted my trims, used 0.7" noise isoliation and 0.5" heat isolation and original carpet.
Here are the photos:
Old Mar 10, 2010 | 08:48 AM
  #102
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I'd like to see more on the install of this cage, also that's an 8pt correct. You stated 10pt in your original post. Anyway I am looking into getting Spohns chrome moly 8pt cage for myself. I was wondering if you got the side bars to clear oem handles, as it appears you do. Also how was fitment and if possible post some pictures of the install. Any problems, concerns, something you would do different? Thank you.
Old Mar 10, 2010 | 08:56 AM
  #103
engongam's Avatar
Engine: 502 Ram Jet
Yes, I was planning on making it 10 point but It would take so much effort so I stayed with 8.
I bought the OEM side bars but they weren't exactly clearing the handles, I needed to do some bendings...
People weld the back bars on the sheet metal covering the fuel tank, but I weled them on the strut beginnings to get have more feeling...
I do not have detail pictures of the install because It was done in another shop. But ı do have some pictures, I will post them later...
The most important thing was the weldin to the car. You should be very careful at the back, because it is to close to the fuel tank, ıt may explode... And the lover front welds melted my undercar coatings so I needed to re coat the weld marks...
Old Apr 11, 2010 | 05:19 PM
  #104
engongam's Avatar
Engine: 502 Ram Jet
here is the progress:
Hello,
I wanted to tell you the progress...
I replaced my oil pan and we are ok about the clearance. I did my shopping=) I bought QA1 double adjustable coilover kit with 225 lbs spring rate to back. Yellow koni's (qa1's and varishocks were extremely expensive...). 2" drop spindles from racecraft. Extended ball joints from QA1, Jegs Panhard bar relocator and finally 1200lbs Eibach front springs, ...
I changed all suspension bars with Spohn del sphere double adjustable bars (LCA,Panhard, Torque arm)
Now what I am asking from you is how those differences effect the car? For example, I changed the distance between rear tires and front tires (I equalized them with computer alignment) The car felt very bad, It was all over the place, front nose dive was ok but rear... omfg. I was changing lanes very rapidly and rear felt like a snake, It was comming after the nose enters, It did not feel rigid. That is what I experienced.
I want to learn what lowering the panhard bar does to car or incresing the a arm angle, or incresing the rebound-compression values of the shocks...
Help me out=)
Old Apr 25, 2010 | 11:25 AM
  #105
engongam's Avatar
Engine: 502 Ram Jet
Some chassis imporevments are in this link: https://www.thirdgen.org/forums/susp...ml#post4521918
(Picking the right rated springs, coilovers, weigh jacks, 2" drop spindles adjustable ball joints etc...)
Old Apr 27, 2010 | 07:04 PM
  #106
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by engongam
I want to learn what lowering the panhard bar does to car or incresing the a arm angle...
There are aftermarket panhard bars that give you better clearance for exhaust.
Changing the A-arm angle moves the instant center of the suspension.
Awesome car you're putting together there.
Old Apr 27, 2010 | 10:52 PM
  #107
engongam's Avatar
Engine: 502 Ram Jet
Thanks a lot=) I am trying to do my best with the help of yours... I guess It would be much better and much more stable when it is finished...
Old May 8, 2010 | 04:24 PM
  #108
engongam's Avatar
Engine: 502 Ram Jet
Here are the updates::
Front shocks and bump steer kit (adjustable koni yellow's)
a arm angles:
Rear LCA relocation brackets and rear coil over conversion(double adjustable QA1's):
Weigh Jacks: (I still did not recieve my drop spindles, adjustable del sphere a arms, adjustable ball joints and front springs so I did not installed them)
Old May 8, 2010 | 04:25 PM
  #109
engongam's Avatar
Engine: 502 Ram Jet
with different tires and ride height pictures:
old rear tires: kumho 275 40 18
new rear tires: pirelli pzero rosso 275 45 18
front dimensions are the same
Old Jul 23, 2010 | 03:02 AM
  #110
engongam's Avatar
Engine: 502 Ram Jet
http://www.streetfire.net/video/su-r...me_2040823.htm
the day will come...
not too far...
Old Jul 23, 2010 | 01:11 PM
  #111
five7kid's Avatar
Love the music and negatives.
Old Jul 23, 2010 | 06:45 PM
  #112
The Devastator's Avatar
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
For the steering pump pulley, I figured out that If a open a place for the bolts to stay in on the bracket, It will be ok to use a smaller pulley.
Of course first I had to say that I was not able to use a smaller pulley because of the bolt heads of steering pump... Anyhow If you guys have any questions I will be glad to answer it...
I still have the same problem with my big block camaro. I'm having a little difficulty understanding your fix for the problem. Which bracket did you grind down? Thanks alot and sweet ride man. That must have been a good chunk of money!
Old Jul 24, 2010 | 04:38 PM
  #113
engongam's Avatar
Engine: 502 Ram Jet
I did not grind any brackets; I just drilled a conic shaped holesto the standart bolt places and used flat headed conin shape bolts. I cnc machined the pulley.
when you do down on pully diameter, it will hit to the ragular hex type bolt heads, you need to open a conic hole and use the exact size bolt to not to cause height difference.
Old Nov 6, 2010 | 01:16 AM
  #114
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
TTT ... I think this thread is one of those that should never be forgotten..
Old Nov 12, 2010 | 04:25 PM
  #115
engongam's Avatar
Engine: 502 Ram Jet
I am going back to my 30tpifor the winter and I will upgeade the 502...
I have a few questions though,
Can I use the new 502 wiring to 305 tpi? All of the injectors, water, map, throttle positon, air flow sensor sockets are the same but only one issue is confusing me...
As you can see in the picture 502 wiring has 2 sockets for the ecm. there is no such thing on the 305, so if I connect all the other stuff and leave those 2 ecm sockets, will the engine run?
and in the first picture, I am holding a hose from throttle bodies, do you know where does it belong?
Old Nov 12, 2010 | 04:39 PM
  #116
KNBlazer's Avatar
Engine: 5.1 4bbl
that line is most likely either EGR, Vapor Canister or to the booster... you need an emissions diagram...
Old Nov 12, 2010 | 04:41 PM
  #117
engongam's Avatar
Engine: 502 Ram Jet
I already took off the air stuff, egr and put heades on it and also canceled the air conditioning, so I will not need it I guess...
Old Jun 1, 2011 | 10:45 AM
  #118
engongam's Avatar
Engine: 502 Ram Jet
http://www.youtube.com/watch?v=nEi-8wsWpWA
www.trackdayturkey.com
I am one of the owners of the site...
here is the generel video of our trackday, i am still with the 305cui... but it handles like !FSDF%T&
CRAZY.... I had a modifed corvette and a new camaro ss in front of me and I always reached them in corner but on staights.. mmpphh, the gap again increased...
Old Jun 1, 2011 | 10:52 AM
  #119
engongam's Avatar
Engine: 502 Ram Jet
and also you can find photos in facebook group of ours...
http://www.facebook.com/#!/home.php?...09413699142880
Old Jun 4, 2011 | 12:48 AM
  #120
85z28kid's Avatar
Car: 85 iroc-z28
Engine: 049 headed bbc 4?? C.I.D
Axle/Gears: 3:73 posi
i think you had your motor mounts switched around on the first install of 502 they are differnet and i think that a 140 casting number is drivers and other one is passsengers i hope someone will back me on this tho. great build looks great doesnt look like you can do much more lol. how did you mount your sparco's and how do you like not being able to adjust the tilt? thanks
Old Apr 18, 2014 | 06:42 AM
  #121
engongam's Avatar
Engine: 502 Ram Jet
Hello again...
It hass been a while since I update this thread...
This time, I am really getting into it... A lot of things happened in my life. I even finished my military responsibilty and today, it's my final day...
When I get back to Istanbul, I will dig in to the car.
I will be doing many stuff,
Like putting the rebuilded 502 ram jet in it, putting fiberglass doors, hood on it, putting lexan all around the car, welding a 14 point cage, etc etc...
I will be keeping this thread alive...
For a started, this is how the car looks like right now in the welding shop:
only diff and brakes are on the car, nothing more
I created a program for the car during military responsibilty, It is öake me see all the values such as , oil temp, oil press, rev/m, speedo all the thing that you see on the gauges will be in the car's system. It will have a 7" touch screen display so that you can do geek stuff with it.
I will explain you more about in detail when I get back to my home/garage...
But I can tell you that I am very excited and very looking forward to get back on working on it again...
ps: Dean, thanks for all your help again...
and I ve sent emails/pm's to some of thirdgen.org users that have done similar things to their cars, I can say that I am open to supoort and actually asking for support from those guys who actually did the things that I am doing right now.
Attached Thumbnails Finally it is happening (305-502, auto- manual, drum-disc swaps...)-10157237_292231334276014_203127229498778191_n.jpg
Old May 28, 2014 | 11:53 PM
  #122
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
wow, sounds like a real monster. nice job.
Old Jun 21, 2015 | 03:16 PM
  #123
engongam's Avatar
Engine: 502 Ram Jet
let me update you guys a bit with the photos, I realized that all of the photos are gone for no reason...
You can also follow me on instagram berk_engin or facebook, /berk.engin.50
nitto nt05's
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Ian Irvine
Sep 4, 2015 08:08 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
