ingine id???
Old Oct 22, 2008 | 09:03 PM
angelz28's Avatar
ingine id???
I cant find this one
K0224TPA
they told me it is a 350.
is it??
Old Oct 22, 2008 | 10:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Get the block casting number.
Old Oct 22, 2008 | 11:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: ingine id???
Truck block. Probably from a pickup or van
K= St. Catherines, Ontario engine plant
0224 = Feb 24
TPA = ?? I can't find TPA but the T normally indicates it as a truck block.
Double check those last 3 digits. A casting number can give you a rough year and what the bore size should be.
Guessing at possibilities...
TPB = 307
TRA = 307
TBA = 350 in 3 different years and a 265 in 1956
Old Oct 23, 2008 | 08:23 AM
angelz28's Avatar
Re: ingine id???
0224 = Feb 24
TPB = 307
TRA = 307
thanx man!!!!!
Old Oct 23, 2008 | 06:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: ingine id???
There's another series of numbers stamped with those ones. You can get a year code from those numbers to narrow it down.
Old Oct 23, 2008 | 06:50 PM
angelz28's Avatar
Re: ingine id???
ok
Old Oct 24, 2008 | 02:27 AM
Klewis89RS's Avatar
Car: 86 IROC, 90 F-250
Engine: LB9, 460
Transmission: 700R4, C6
Re: ingine id???
whats an ingine?
maro323
Mar 25, 2014 08:44 PM
maro323
Mar 20, 2014 09:13 AM
jchaussee
Jan 22, 2011 05:08 PM
JByrd6996
Apr 20, 2010 06:31 PM
