305 to 350 swap will this work
Car: 1991 camaro z28
Engine: 305cu/tpi
Transmission: auto
I know I post a lot of stupid questions about stuff but it is cause I believe you have the most valuable information around. As you can tell I have a 91 z28 with a tpi 305. I was wondering what would I have to do make this engine work in my car. http://www.yearone.com/serverfiles/f...ain2.asp?cat=G It is a crate engine from yearone. Any help would be grateful. If the link doesn't work it is on the yearone website part # CT350PC1 Would I be able to keep the tpi set up if i buy the SD tpi baseplate
Transmission: 4L80E/4L80E
Search on the part number he gave.
You'd need something more like the Vortec style Holley/Weiand Stealth Ram.
