Fuel System Pressure
Old Nov 10, 2008 | 12:34 AM
RTGTA's Avatar
Car: 2009 Silverado 1500
Engine: 5.3 Vortec
I was thinking of swapping my LB9 for a GM Performance 350 Ram Jet or ZZ 350 and was wondering what the stock fuel system could support for ponies. The 305 was rated at 235 horse but would the factory fuel system have enough pressure to support 350 or 400 horse? Any opinions and/or solid number figures on fuel system pressure is greatly appreciated. Thanks all!
Old Nov 30, 2008 | 04:07 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Fuel System Pressure
I think the stock fuel system is inadequate for 400hp. But, you really only need a fuel pump upgrade to bring it up to par.
Look at the many aftermarket pumps available from wallbro, holley, etc. Get something in the 255 lph range. You can support 400hp with that pump.
It's not the pressure, the GM settings at 41-47 psi or so is adequate; the delivery volume is what is lacking. You can set your regulator in the high 40s low 50s psi and the volume of the above aftermarket pumps is fine.
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
jklein337
Sep 19, 2018 06:23 PM
Kaweh
Aug 9, 2015 02:54 PM
