tpi swap
Old Nov 11, 2008 | 02:40 PM
1bad66ss's Avatar
Car: 66 Chevy II SS/89 iroc
Engine: 355/305
Transmission: 350 Turbo/T5
Axle/Gears: 3.08 posi
tpi swap
I'm not sure this is the right forum for this, but I'll give it a shot. Has anyone ever swapped a complete 350 tpi out of a 3rd gen into something other than a third gen? If so did they use the original harness? I don't have the funds available to go buy a aftermarket wiring harness like most people do. After searching a number of sites where people have done the conversion, I have yet to find any definitive answer to the stock wiring harness. I.E. what wires can I eliminate and what must remain.
Any links which will help me out would be great
Old Nov 13, 2008 | 12:42 AM
lnsper's Avatar
Car: 92 RS
Axle/Gears: 3.27 4 wheel disc
Re: tpi swap
I have a SD 90-92 350 TPI ECU and harness that has allready ben trimmed that I would trade for a 305 SD set up with a stock harness Let me know if you a interested
Thanks Shawn
Old Nov 13, 2008 | 06:33 PM
1bad66ss's Avatar
Engine: 355/305
Re: tpi swap
Thanks Shawn
Mine wasn't a sd harness,what I was hoping to get was some info from some one who had done a tpi swap in an older vehicle. And had used the original harness, but it looks like from the lack of replies that no one one this board has done it.
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
