how difficult is it going to be to swap the 283 into my car? i have a 91 camaro rs with a 3.1 in it now.
anything that im going to run into on the way? has anyone done this?
five7kid
close
It's a V6 to V8 swap, except the 283, if original heads, won't have accessory bolt holes on the ends, so you'll have to come up with some means other than 3rd gen to mount accessories.
Quote:
Just to play devils advocate... a set of 305 heads would solve that problem, and would work nicely on the small bore 283 Originally Posted by five7kid
Quote:
So your saying that all I have to do to make it ft in my car is get me a different set of heads from a 305 and it will work out fine?
Well of course the motor mounts are different, you need a different tranny, depending on what your planning for induction possibly an ECM. I suggest you read the v6-v8 swap it will most likely answer most of your questions. James
Since you have to change so much, why are you even using a 283? It's easier to just drop in a 305 or 350.
five7kid
close
Quote:
No, no, no. Mounts are the same if '58-'67, '57 was the only year for 283 that didn't have the side mounts. Transmission mounts the same, but the starter could be trouble (bolt holes/pad may not support later starter). Induction - it's just a Gen I SBC.Originally Posted by IrocZ30589
Well of course the motor mounts are different, you need a different tranny, depending on what your planning for induction possibly an ECM. ----------
Quote:
As far as mounting 3rd gen accessories goes, anyway.Originally Posted by xsupermann69x
So your saying that all I have to do to make it ft in my car is get me a different set of heads from a 305 and it will work out fine? Too bad you're not closer, I have a set you could have for the taking.
JPhillis
close
- Join DateMar 2008
- LocationMocksville, North Carolina
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car1992 Camaro
- Engine350 .030 over 298 cam 9.1 Flat tops
- TransmissionT5 swap complete
- Axle/Gears3.73 posi the 4.10s are history
- Liked:0 Times in 0 Posts
I have a set of 305 heads I would part with. They are the 193's. Came off of my 92 305. They should just need cleaned up. The car ran ok and did not smoke on start up. If you want to come get them thats fine I live pretty close to you I think.
five7kid
close
193's are swirlport heads. Not recommended. 416, 601, or for '87-later intake bolt pattern, 091's are much better.
Although on a 283 it might not matter.
081 right Five7 ?
wow im surprised only one person has said anything about why a 283 and not some other bigger sbc? lol go with what u want though man, i do wonder though why a 283? (not that im trying to convince you of somethin else)
five7kid
close
Quote:
Fat finger. Originally Posted by Sonix
081 right Five7 ?
Yes, 081.
robertfrank
close
- Join DateApr 2004
- LocationSalt Lake City, Utah
- iTrader Positive Feedback100
- iTrader Feedback Score(27)
- Car1988 camaro "SS"/ 1991 305/T5
- Engine383 LT1 in progress/LT1TBI 355 soon
- TransmissionProbuilt 700R4 3600 stall/ T5
- Axle/GearsMoser axles, 3.42 Eaton Posi
- Liked:62 Times in 44 Posts
I would think that a ported set of 187's would probably be good for that little motor. it gonna need all the bottom end torque that it can get.Originally Posted by five7kid
193's are swirlport heads. Not recommended. 416, 601, or for '87-later intake bolt pattern, 091's are much better.Although on a 283 it might not matter.
Quote:
Yes, 081.
Fat finger.
Yes, 081.
Quote:
Learn something new everyday. Why I love this site. To clear up any confusion I should have said, the v6 tranny uses a 60* bellhousing apposed to the 90* pattern of the smallblock.Originally Posted by five7kid
