454 swap in 87 iroc
Old Nov 18, 2008 | 08:27 PM
wildchildracing's Avatar
454 swap in 87 iroc
hi im about to buy a 454 out of a 1 ton pickup for 800 and put it in my 87 iroc. ive had some people tell me not to put this is my car. does anyone have any advice on this.i dont want to spend this money for something thats a waste to put in it. thanks
Old Nov 18, 2008 | 09:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, there's a sticky about putting a BBC into a 3rd gen in the top section of this forum.
Old Nov 18, 2008 | 10:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 454 swap in 87 iroc
Depends on the engine. They're not all the same. What year is it?
Truck engines are low rpm torque motors. They're usually a good platform for a buildup but don't expect much more performance in stock trim than a good 350 SBC. The first thing that should be replaced is the cam and lifters followed by the intake and probably carb. Depending on the castings, the heads are probably restrictive peanut port heads but there are a few good older castings.
If you follow the sticky, the swap isn't that hard but it's not as easy or cheap as a good SBC.
Old Nov 19, 2008 | 05:33 PM
will i be able to use the tranny thats already in the car
Old Nov 19, 2008 | 06:00 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
it will bolt up but ull need to have it built to withstand the torque when u make that motor really put out power.....
Old Nov 19, 2008 | 06:07 PM
five7kid's Avatar
That is covered in the sticky.
Fast355
Dec 2, 2016 06:33 PM
sreZ28
Aug 14, 2015 07:48 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
