3 questions?
Old Nov 29, 2008 | 07:55 AM
91Zconvert's Avatar
Car: 91 Z28 ragtop, 88 SS monte
Transmission: auto
3 questions?
i have a 85 berlinetta that used to be a 6cyl.the dipsh%t who had it before me changed it to a 350 without changing the harness and it is rigged up so the best thing for me to do is change it back to a 6cyl and start over?
i also have an 86 6cyl camaro (non-berlinetta)that runs very good but the trans is on it's way out.it does have a new exhaust,so i plan on taking that exhaust and putting it on the 85 berlinetta.
what i want to do is change the 85 berlinetta back to a 6cyl.
so my questions are:
#1-is the 86 6cyl the same as an 85 6 cyl?
#2-would it be an easy swap since my 85 used to be a 6cyl?
#3-is the trans in the 6cyl the same as the trans in the 8cyl?(700r4)
Old Nov 29, 2008 | 11:03 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 3 questions?
transmission has a different bellhousing, but other than that, go ahead and slam the '86 engine in the '85.
Old Nov 29, 2008 | 11:06 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 3 questions?
You don't have to go all the way back to a V6 to start over.
Old Nov 29, 2008 | 10:55 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
Re: 3 questions?
BBBBOOOOOO 6cyl
YYYYYYAAAAAYYYY fix the harness problem
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
