383 or not?
Old Dec 7, 2008 | 05:23 PM
camarod24's Avatar
Car: 1986 Camaro Iroc
383 or not?
I bought a car from a guy and he claims it is a 383. Is there any way to tell without tearing down the engine? He claims that it was just rebuilt. The car runs REALLY strong and I can tall it has new headers on it I have driven 350s and it seems to have more power. Is there a quick tell?
Old Dec 7, 2008 | 05:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 383 or not?
No
Old Dec 7, 2008 | 06:32 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 383 or not?
You can check the casting number to determine if it's a 305 or a 350 block.
The majority of 383's use an externally balanced crankshaft. This can be determined by seeing the offset in the harmonic balancer. If it's using an externally balanced crank, it can be a 334, 383 or 400.
If it was just recently rebuilt, ask for the receipts. It would have had machine work done to it. The machine shop will say what the specs of the engine are.
Old Dec 7, 2008 | 07:09 PM
camarod24's Avatar
Re: 383 or not?
what do you mean by the offset? Does anyone have a picture of what it would look like?
Old Dec 7, 2008 | 07:32 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: 383 or not?
It will look like a chunk taken out of the balancer instead of being smooth all the way around.
Old Dec 11, 2008 | 02:16 AM
SLOWMARO355's Avatar
Re: 383 or not?
Drop the pan. Casting number is on crank. Must be 350 block also.
Would need line boring and .030 over. Reciepts?
Old Dec 20, 2008 | 09:37 PM
blp226's Avatar
Re: 383 or not?
I doesn't have to be externally balanced to be a 383. I built my 383 and it is enternally balanced. There is no way you can look at mine and tell if it's a stroker or not. There is no real way to tell if yours is either. What size carb do you have? Does the engine lope? The reason I ask is if its got a smooth idle and a 750 carb and it runs really hard it's possible its a stroker.
Old Dec 21, 2008 | 07:18 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: 383 or not?
Originally Posted by Apeiron
No
Thank you Apeiron!
Everyone see the motor pictured?Looks like a 383 stroker doesn't it?
Well its not.A 383 stroker would look the same but,unless you or someone you personnally know built the engine there is no telling without a disassembly what is truly in your engine.
BTW,the engine pictured is mine and its just a standard bore l98 with 87 corvette heads.
Old Dec 22, 2008 | 07:25 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: 383 or not?
If he had it built and doesn't have receipts - that would make me go Hummm?
But, being a possibility I'd ask how much is it over bored, what type of piston specifically the compression height and I'd ask if the rod is 5.7", 6", and what block mods were done. If he can't answer those I would definitely find out what it actually is.
Mine looks like the picture above, but is a 388/3.63Liter:
  1. 4.06" Forged 1-1/8" compression high, -16cc D-dished pistons.
  2. 6" rods
  3. 3.75" crank
  4. Motown 350 race block - stroker clearanced - bored 60 over.
Old Jan 4, 2009 | 01:53 PM
elano's Avatar
Car: 86 IROC-Z, 82 z28
Engine: 383 Stroker
Transmission: TH-350
Axle/Gears: 3.73 Torsen, 4.56 Auburn
Re: 383 or not?
The 383 will have a 350 block and a 400 flywheel since the crank comes from a 400. This means that it will have to either have a 400 flywheel or a bolt-on balancing plate. The flywheel will have a counterweight on it. I think that's right.
Old Jan 4, 2009 | 03:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 383 or not?
30 years ago you could assume that was true, but not anymore. There are lots of internally balanced 383s out there that are completely indistinguishable from a 350 without taking it apart.
Old Jan 4, 2009 | 03:26 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 383 or not?
exactly.
my motor is a factory 350 block with a 4" stroke crank (408"), internally balanced, from the outside, it could pass as a 305, 350, 383, ect.
unless the guy has some paper work from the work done, there is no way to tell.
Old Jan 11, 2009 | 04:04 PM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
Re: 383 or not?
i would imagine that if you pulled a plug and had a a volumetric vacum gauge and crank it to bdc on the power stroke, you could compare to a 350. how do they govern the circle burners with cube limits? i guess they just tear them down if you win?
Old Jan 11, 2009 | 04:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 383 or not?
You can have several engines of wildly different displacement that all have the same readings on a vacuum or compression gauge.
Racing engines are either homologated, certified when they're built, or torn down and inspected.
Old Jan 17, 2009 | 05:40 PM
92coop's Avatar
Car: 92 rs camaro
Transmission: 5 speed
Axle/Gears: 3.08
Re: 383 or not?
if its a 383 it should have an 8in balancer than the 6in on a 350
Old Jan 17, 2009 | 05:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 383 or not?
Unless the 350 has an 8" balancer, or the 383 has a 6", or any other combination.
Old Jan 17, 2009 | 05:46 PM
92coop's Avatar
Car: 92 rs camaro
Axle/Gears: 3.08
Re: 383 or not?
currently i have a 305 i have an 383 rpm performer late model 425 horse carbarated i want to use the tbi on the 305 how much modifications will i have to do to make this happen
Old Jan 17, 2009 | 06:29 PM
Re: 383 or not?
uh what....
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
