Swap to a 5-speed
Old Dec 14, 2008 | 09:03 PM
camarod24's Avatar
Car: 1986 Camaro Iroc
Swap to a 5-speed
I just fially got my 305 out a few hours ago I am also switching to a 5 speed and was wondering what all I need to do to switch to a 5 speed?
Old Dec 15, 2008 | 01:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Your post didn't have anything to do with the thread in which you posted it, so I moved it to its own thread.
Check the tech articles linked from the thirdgen.org homepage. There's an article about swapping from auto to 5-speed.
Old Dec 20, 2008 | 05:27 PM
zoddri's Avatar
Car: Camaro -88
Engine: 2,8 V6
Axle/Gears: yep, got that as well
Re: Swap to a 5-speed
Speaking of this.
I was thinking about swapping to a 305 instead of fixing my V6, need something to do now that all other cars are working
Can I use the same gearbox (5-speed manual) that is currently bolted to my 2,8 or is it too weak for the 305? I know the 305 came with manual transmission but is it the same?
Old Dec 21, 2008 | 12:08 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
No, V6 T5's and V8 T5's are different. Most notably the bellhousing, and the internal gear ratios. Some people have successfully used a V6 T5 with a V8 bellhousing on a V8 engine, but its not recommended.
Search the Tranny/Drivetrain forum for more info. Its a pretty common question.
jhawkeye
May 25, 2022 06:33 PM
RedLeader289
Jan 22, 2016 03:05 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
