Camaro 305 into 94 blazer
Old Dec 24, 2008 | 07:33 PM
robster66's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 305 T.B.I.
Axle/Gears: 2.73 Open Diff
I have an extra 305 from a camaro and I never did a motor swap before so I figured I could practice on my truck. It is pretty quick already for what it is. I wanted to know how hard this would be and if anyone knows any guides for doing this. I would probably build the motor before I put it in and keep the same T.B.I. fuel injection. Could I use the same computer and what would I have to do? The motor it has in it now is a 4.3l
Old Dec 24, 2008 | 09:05 PM
Kwik89GTA's Avatar
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
Re: Camaro 305 into 94 blazer
The mods will probably delete this thread but.... Buy the s10 swap manual from Jags That Run publishing. Summit sells the book also. http://store.summitracing.com/partde...5&autoview=sku
Kevin
Old Dec 25, 2008 | 09:05 AM
robster66's Avatar
Engine: 305 T.B.I.
Thanks, I figured I would do a swap on a vehicle that I do not like that much to practice.
Old Dec 25, 2008 | 12:16 PM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
I swapped a roller 305 into a 92 blazer and kept the original tbi. It runs fairly decent but leaves a lot to be desired. Apparently mine came with a 92 4.3 ecm specific to this truck and I cannot find a chip or replacement v8 ecm for it. Yours should be a lot easier. Just find yourself a 305 ecm from a 94 k1500 and it should be a plug and play affair. Just double check your pin outs. Good luck.
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
