350 vortec swap
350 vortec swap
hello there the engine iin my 89 v6 camero has gone to crap.and a friend of mine is going to do some tradeing with me to get a 99 vortec engine.(pretty sure its a 99)i am going to go carb on the engine i beleave that should save me a lot of problems.i would also like to know your input on this.and maybe any help or adivse you could give me that maybe useful.thx
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
It's basically a V6 to V8 swap with the minor Vortec details. Be sure to read the V6 to V8 swap sticky in the top section of this forum if you haven't already.
Accessories, transmission, and exhaust are going to be your main issues. The Vortec-ness of the V8 is a very minor detail.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 350 vortec swap
It will be just like swapping in any '87+ 350 engine. The only difference the "Vortecness" of the engine makes is with the intake manifold, as you'll need a special one for those heads. Everything else is the same. Below the heads, its basically the same engine as the 350 TPI.
Car: 87 GTA
Re: 350 vortec swap
What are you gonna do for a transmission? Vortecs used a 4L60E, so you'd still have an ECM to deal with, unless you go 350/400 or 700R4.
Re: 350 vortec swap
you know it may sound odd but i haven't looked up much on a tranny.do you have any idae what kind of ecm i should use.or maybe i should do a way with the sensors some how.i was going to get rid of the sensors and ecu,but someone told me today that i have to have the camshaft sensor for everything to work properly?lol its all so confuseing to me lol.i know a bit about old school sbc,but all the sensors and the ecu cofuse me .lol.
thatnk you very much for your replys.its very helpful.
Re: 350 vortec swap
If you're using a 3rdgen EFI system (TPI or TBI) or a carbureted setup, you'd use whatever trans a 3rdgen would use with that setup... I think that would only be the 700R4 (4L60, not 4L60E) or a T5/T56 setup.
Like I said, as far as the engine goes, its the same as what the 3rdgen V8 cars came with, and the same transmissions will work. The only thing that might make a difference is if you use a more modern EFI setup (LT1 or LS1 for example).
Car: 87 GTA
Re: 350 vortec swap
Yes...The dizzy has a crankshaft sensor in it. And there is a cam sensor under the timing cover.
But if you go carbed, just disconnect them & your good.
Now...As for the ECM for the tranny....I wouldn't be surprised if Painless has an stand alone ECM, just for a 4L60E tranny.
I certainly wouldn't bother with the Vortec induction/ignition/PCM stuff. It could perhaps be swapped into an f-body, but it wouldn't be emissions legal.
You only indicated you were getting the engine, is the transmission in play as well?
Re: 350 vortec swap
the only tran i have atm is the t5 in the car right now i'm curently doing some research as to what tranny i should go with and what i need to make it work.i don't beleave the emissions testing should be a problem for we got rid of it a few years back.i'm pretty sure if i need to i can get a the tran that came off the vortec.
Re: 350 vortec swap
i was wondering if someone could help me pick out a distributor for my aplication.i'm getting rid of all my computer stuff and need a distributor that will work for my block.ive searched everywhere and can not find any info on this any input would be great.
That isn't emissions legal, of course.
You need one that has mechanical and vacuum advance. Summit has a large cap coil-in-cap type for about $90. One with a good cap & rotor is a little more.
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: 350 vortec swap
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 350 vortec swap
The truck tranny isn't any solution for you. Let it go. Your V6 trans might live if you baby it, but it would require the V8 T5 bellhousing and then you have a clutch issue. Or a flywheel issue. There's no ready solution except the V8 S-10 parts from www.advanceadapters.com
Really, trans depends on your preference, budget, desperation to get the car running again, and availability of parts. There's another section of these forums for transmission issues.
Re: 350 vortec swap
well i got all the parts for engine and i'm going to go have it rebuild for the winter. also takeing a look at some cams.and a 383 stroker kit but we'll see how that gose lol.any way i got me a rebuit 700r4 tranny with a shift kit from a freind for $150.and i'm going to buy a new k member for the car.thx for all your help everybody i'll be sure to keep u posted on progress as i get done with my project.
Re: 350 vortec swap
i wanna buy some headers for my application but what i was really wondering if i can use 350 tbi camaro headers or if i would have to to with the 99 subbrban headers.they have some on ebay that seem to be cheap but they also look cheap as well.any help or input on these would help alot thanks.
350 Camaro TPI headers, specifically '86-'90 TPI single cat application, such as Hooker 2055HKR.
(There was no 350 Camaro - or Firebird - TBI)
Fast355
Dec 2, 2016 06:33 PM
