help after swap wont charge
Old Dec 28, 2008 | 05:06 PM
joey19's Avatar
i have a 88 firebird after motor swap it will not charge ive tried 4 different alt no broke wires anyone know if there is a hidden fuse im missing it was charging find before engine swap im so lost where i bought then engine was a local engine shop they said it was a 305 couple guys i talk to said it was a 350 why this would matter im curious if it could be a computer promblem why it is not charging dont see how , starts runs great i just cant get it to charge , i did take a wire and run straight for back of alt to the battery and it was charging anyone have any ideal im so desperate
[quote=joey19;3989172]i have a 88 firebird after motor swap it will not charge ive tried 4 different alt no broke wires anyone know if there is a hidden fuse im missing it was charging find before engine swap im so lost where i bought then engine was a local engine shop they said it was a 305 couple guys i talk to said it was a 350 why this would matter im curious if it could be a computer promblem why it is not charging dont see how , starts runs great i just cant get it to charge , i did take a wire and run straight for back of alt to the battery and it was charging anyone have any ideal im so desperate
Old Dec 28, 2008 | 05:48 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: help after swap wont charge
sounds like the alt isnt gettin a reference voltage. There should be a constant hot and a switched source hot on your alt if its a tpi style alt. take a picture of where the plug goes into the alt and ill can tell ya witch one needs what.........i had the same problem on my old setup it was an easy fix
Ikes 91Z
Dec 9, 2015 03:49 PM
mddaniel
Sep 8, 2015 05:16 PM
gixxer92
Sep 1, 2015 04:32 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
