need help, decided to upgrade tpi
Old Dec 31, 2008 | 06:40 PM
73duster's Avatar
i recently said that i wanted to convert tpi to carb, but after thinking about it i'm going to upgrade the tpi. I'd like to get the holley stealth ram intake and plenum and bolt it on a 383 stroker. MY question is can i still use my stock wiring harness and ecm or do i have to also go with the commander setup? I don't know anything about tuning or chips so any advice? I rather use the wiring and ecm already in the car and just get the right chip to replace with.
Old Dec 31, 2008 | 07:00 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: need help, decided to upgrade tpi
Yes, you can use your factory TPI harness, as the Holley Stealth Ram is a direct replacement for the stock TPI setup. New PROM, injectors, and AFPR, and your good to go. My cousin did this years ago, it's a good upgrade. Here is my buddy Rob's website, Click here....
Old Dec 31, 2008 | 07:06 PM
73duster's Avatar
does'nt the stealth ram come with fuel rails, injectors and regulator? I'd like to get the intake as a complete setup. Also how do i go about the prom and getting a proper tune? thanks
Old Dec 31, 2008 | 07:13 PM
You can definitely go with the entire setup, but most guys just buy the intake alone, then buy the necessary components afterward as a means of saving a few bucks. Aftermarket rails, and injectors can be had for very cheap nowadays, so people avoid buying the whole HSR setup upfront. If your new to tuning, and your in New York, ask Carmen over at the vettedoctors, Click Here, to burn you a PROM (chip) after you get the engine reassembled. He is the only guy I would recommend in New York, because I know his work very well....
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
