V6 5 speed to 350 V8 with T5 tranny
Old Jan 4, 2009 | 12:27 PM
tom marvolo's Avatar
I'm new to this so I have some basic questions about 82's-84 Z28.
1. Will a T5 work with a 350 V8.?
2. Can I swap a V6 to a 350 V8 without changing the rear differential?
3. Is this a bad idea?
Old Jan 4, 2009 | 02:46 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: V6 5 speed to 350 V8 with T5 tranny
Welcome to thirdgen.org! First of all, use the feature to help you find your answers.
82-84 would be a Z28. The IROC's were 85-90. In 91-92 they are back to Z28.
A V6 T5 can work with a V8 if you change the bellhousing to a V8 model, but the V6 T5 is even weaker than the V8 T5 so its not recommended.
Yes you can use the same rear end, no problems there.
Yes its a bad idea to try to use a V6 T5 with a V8, but its not a bad idea to change a V6 to a V8 if you know what you're doing. Its not something for a newbie, though.
Old Jan 4, 2009 | 06:19 PM
My mistake on the IROC's but thanks for the correction and thanks for the info. I don't have allot of money right now so I can't afford a 6 speed and 350 V8 so I'm just looking at my options. I have a 84 5 speed camaro with a V6. I want to do an engine/tranny swap... Thanks again!!!
thekurlyone
Sep 30, 2015 12:54 PM
apie2546
Sep 20, 2015 01:03 PM
Stryker412
Sep 7, 2015 09:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
