305 to 383?
Old Jan 25, 2009 | 01:18 PM
Dime333's Avatar
Car: 1985 Camaro Z28
Engine: 305 5.0L (LB9)
Transmission: 700R-4
Axle/Gears: No idea
305 to 383?
I need to know if i can upgrade my 305 to a 383. will i have to change my set up to carb or can i keep it as TPI? my Camaro has the LB9 block
Old Jan 25, 2009 | 02:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No, can't be done. The 305 bore is 3.736", a 383 is a 327/350 block with a 4.000" bore which has been overbored to 4.030". With the 3.75" stroke, that comes out to 383 cubic inches.
If you put a 3.75" stroke crank in a 0.030"-over 305, you come up with 334 cubic inches. Before you ask about that, read https://www.thirdgen.org/forums/faq-...5-stroker.html .
The most you can safely bore the typical 305 block is .060". 3.736" + 0.060" = 3.796" - well short of 4.030".
You can keep TPI with a 383, but it will be very restricted. You can upgrade the TPI hardware to handle it. But, emissions legality will become a problem with the "better" TPI upgrade hardware. The only emissions legal carb is the factory computer controlled type.
Old Jan 25, 2009 | 09:05 PM
Reed35's Avatar
Car: 84 Trans Am
Transmission: TH350
Re: 305 to 383?
My suggestion, if you have the resources, drop in a 350. If will bolt straight in, and you can build it to a 383 from there.
mhatfield 14
Oct 24, 2015 07:48 AM
angel2794
Sep 8, 2015 06:22 PM
gixxer92
Sep 1, 2015 04:32 PM
5spdcamaro
Aug 28, 2015 02:12 AM
bdads
Aug 24, 2015 06:01 PM
