stock flexplate and 400 hp?
Old Jan 30, 2009 | 04:44 PM
73duster's Avatar
How much power can the stock tpi flexplate handle? I want to drop in a 400 hp 383 tpi motor in my 91 z28 and i'm trying to save a few bucks.
Old Jan 30, 2009 | 06:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It'll handle 400 HP easily enough.
Is your 383 internally balanced one-piece rear main seal?
Old Jan 30, 2009 | 07:48 PM
73duster's Avatar
Re: stock flexplate and 400 hp?
one piece rear main seal, i says on their site it's a balanced rotating assembly. I don't know if that means internal or external.
Old Jan 30, 2009 | 07:49 PM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
I had a stock replacement flex plate from pioneer and it cracked 3/4's of the way around the crankshaft the first time I jumped on it from a dig. I am making alittle more than 400 but not like 500 or anything. A good SFI approved plate is pretty cheap insurance against dropping the trans a second time.
Old Jan 30, 2009 | 11:04 PM
five7kid's Avatar
You need to know that. If it uses a stock type neutrally balanced damper, you can use a stock type balanced flexplate.
I'd have to agree, though, that $65 in a 383 budget doesn't seem excessive, especially for the peace of mind you get for it.
84z96L31vortec
Aug 20, 2017 12:16 AM
Genopsyde
Oct 7, 2015 08:35 PM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
