how do i find out what this motor is from
Car: 1987 IROC-Z Camaro
Engine: 350ci
Axle/Gears: stock 3.27
i bought an 87 iroc camaro recently. the guy said teh 350 was out of a 71 vette. i bought everything to do a tune up to a 350 out of a 71 vette and everything is wrong. how do i find out what this motor is really out of?
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
Re: how do i find out what this motor is from
Casting number. It is on the drivers side, on the back of the block, next to the distributer.
Look here: http://www.mortec.com/location.htm
That site also gives number I.D. But that will tell if if it is atleast a 350 or not.
EDIT I did some research, the 350 cid engine with 270hp that came in the 71 Corvette had a block casting number of 3970010. Hope this helps you.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
010 castings were used in just about everything and was used for 302, 327 and 350 blocks.
An engine that was "out of a vette" doesn't mean as much as it did 30 years ago. All it's good for now is if someone was building a numbers matching car and needed a vette engine.
Look for the stamped numbers in front of the passenger side head. Those numbers will tell you a lot more than the casting number.
The tune-up parts are relevant to what is bolted to the engine now, not 30 years ago. The are more corvette engines out there than there were ever corvettes made.
ambainb
Apr 25, 2016 09:21 PM
