Drive pulleys?????
Old Feb 11, 2009 | 07:57 PM
nitemare70's Avatar
Car: 83 Z28
Engine: Comp Controled 350 w/ carb
Transmission: 5 Speed
Drive pulleys?????
I am looking ahead towards the completion of my 305 to 350 swap. I just want to be looking for needed parts on the way. I have a 90 350 going onto an 83 Z28 with T-5. I noticed the harmonic balancers of the 2 motors are different in size. The 305 is thicker. I had planned on using the 305 pulleys (all V-belt), but I am wondering if the grooves will align. The 350 had a serpentine system that I only have the crank pulley. Any suggestions or can I use the 305 crank pulley with out too many mods to the other accessory mounts?
Old Feb 11, 2009 | 08:02 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Drive pulleys?????
The drive accessories will swap without issue between, no mods needed. They're "thickness" will not alter the fact that the crank snout betwen the 2 engines sticks out the same, so the mounting bolts of the 2 dampers sits at the same position in relation to each block.
Old Feb 12, 2009 | 03:35 AM
nitemare70's Avatar
Car: 83 Z28
Thanks!! I thought I would have to scour Junkyards for pulleys!
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Navy8125
Aug 22, 2015 07:13 PM
mcquigg
Aug 13, 2015 02:26 PM
