Could I put a carb on my 3.1?
Car: 1990 Firebird / 1999 Eclipse
Engine: 3.1 v6 / DOHC 2.0
Transmission: Automatic / 5 Speed Manual
Would the carb from the 2.8 fit it? What mods would I have to do?
and I know it won't have as much power. We're sticking it in a small pickup.
Transmission: 4L80E/4L80E
It'll fit.
A 3rd gen carb'd 2.8 would be computer controlled. I know the '80 X-body carb was not.
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Could I put a carb on my 3.1?
You need the 80 Chevy Citation carb and big cap HEI distributor, with the S10 or Camaro carb intake from 82-84.
You will also have to run the aftermarket electric fuel pump for low pressure carb applications (7psi-ish) that most auto parts stores sell off the shelf because the engine doesn't have the mechanical fuel pump provision on the timing cover that the old 2.8 has.
86IROC112
Aug 17, 2015 02:00 PM
GVMV
Aug 16, 2015 08:01 PM
