350 swap
Old Mar 6, 2009 | 05:38 PM
da_jester's Avatar
Car: 1992 camaro rs
350 swap
ok so i have a few questions.i have 92 rs camaro with a tbi 305 now i found someone localy with a 350 from a 83 pickup will i need to do any special to install this? and will my intake manifold with tb bolt onto it? id rly like to keep with tbid.
Old Mar 7, 2009 | 12:43 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The '83 engine will be 2-piece rear main seal, so you'll need to find a 153-tooth flexplate (if auto tranny) or flywheel (if manual tranny). The '83 f-body V8 application will be fine.
The heads on the '83 engine have all of the intake manifold mount bolts and a 90 degree angle. The TBI manifold has the center two mount bolts on each side at 72 degrees. You can try to modify the bolt holes to make them 90 degrees, or you can get a carb manifold with the proper bolt holes and get a TBI to carb adapter plate.
Everything else will be the normal 305 to 350 TBI stuff.
Old Mar 7, 2009 | 09:37 AM
da_jester's Avatar
Car: 1992 camaro rs
Re: 350 swap
thank you very much id imagine you can get a flexplate rite from summit or so?
Old Mar 7, 2009 | 03:01 PM
five7kid's Avatar
Correct. But, if you build a 383 that's not internally balanced, you need a 153-tooth flexplate that is weighted.
xkingcodex
Feb 12, 2020 07:43 PM
bellez77
Sep 5, 2015 08:39 PM
theshackle
Aug 22, 2015 06:52 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
