engine noise at 3000rpm
Old Mar 6, 2009 | 06:23 PM
saliger64504's Avatar
Car: 1984 firebird trans am
Engine: 383 stroker
Transmission: th350
Axle/Gears: 10 bolt posi with 373 ring and pini
im neding a little help finde out what is going on with my engine its a 88 350 bored 40 over when i start the car it sound sfine but when i gget up to 2500 to 3000 rpm i hear a ticking sounds it pick up with the rpm's is it a lifter tap or something worse
Old Mar 7, 2009 | 12:44 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You'd normally hear a lifter tap at idle as well.
Try taking the accessory belt(s) off and see if the noise goes away.
Old Mar 7, 2009 | 03:03 PM
Engine: 383 stroker
Transmission: th350
Re: engine noise at 3000rpm
all my accessory are new new power staring pump with pully and a new alternator.
also last night i was looking around my engine bay and i think i might of found the problem my harmonic balacer wobble's so im going to take and get a new one this week and see if that takes care of it
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
BlackBoulder
Aug 11, 2015 11:15 PM
