will aluminum 86 vette heads work on 87 lg4??
Car: 80,81,85, trans am
Engine: 4.9,301turbo,350
Transmission: all auto
Axle/Gears: 308,342,308
i have read alot about the 113 vette heads and problems with them fitting f-body. also with the 305. now are the 86 aluminum vette heads exact same as f-body l98 heads? just alumium? can they be just bolted onto a 87 lg4? hard to find info on this setup. i might need valves etc... for these heads as the heads have been stored outside. thanks.
also these 86 heads do they use up to 86 style intake bolts or 87 up intake bolts??
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: will aluminum 86 vette heads work on 87 lg4??
First, there was no F-Car L98, it was the B2L, because of the iron heads. F-car didn't get aluminum heads until 1993. second, all the L98 vette heads kept the pre-87 intake pattern. Your heads having been stored outside, they may need to spend a night at an automotive machine shop. Once they're good, they will bolt right on to your block. You will need to use 350 head gaskets. If your LG4 is virgin, then your pistons should be about 0.025-0.030" below the decks at TDC. If so, then FelPro steelshim head gaskets are ideal. No special procedure required to use them. Be sure the decks are clean. That's it. Aluminum heads require using washers under the bolt heads, and the bolts still have to protrude from the head by at least 7/16", so check this before placing the heads on the engine. A bit of sealer on the threads, then torque to spec in thr proper sequence. Now, you'll still be around 9:1 compression, so you won't want too wild of a cam, which means you won't have trouble with the valves hitting anything. The heads have no exhaust crossover, which means the EGR won't actually be recirculating anything. But this is how GMPP's legal HO 350 conversion was, as well. The exhaust ports are a bit taller, but the aforementioned conversion used the B2L exhaust manifolds without issue.
thank you for the info. i am looking forward to this. will these heads be ok for the roller cam lt1 that i am using in the roller 87 lg4?
On Probation
Engine: several
Transmission: none
Axle/Gears: none
roller cam LT1? did you convert a '70-'71 LT-1 to roller cam, or is this a '92-'97 LT1? If the former, yes. If the latter, no.
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
(thanks for the thread that Okfoz put up with the above pic)
Car: 1987 GTA
The heads won't work without severe modification to them by welding up the water passages where the intake bolts to them and so on, if you have an LT1 (4th gen) motor already you have better heads than the 'vette L98 heads.
Transmission: 4L80E/4L80E
On Probation
Engine: several
Transmission: none
Axle/Gears: none
My apologies for passing along my misinformation on the technicalities of "L98".
Car: 1983 G20 Chevy
Transmission: 4L60
THe 113 casting Aluminum L98 Corvette TPI heads WILL bolt right up using an 86 & prior manifold and work great on a 305 with NO modification needed. The LT1 cam has around .030" more lift than the L98 cam. Check the springs for coil bind and the valve seal to retainer clearance. I doubt its a problem, given the number of Corvette owners that run 1.6:1 rockers on the stock L98 cam and springs, but its worth checking. Better safe than sorry.
Car: 1987 GTA
I was going to put that as my answer, but went back and re-read the post and it sounded like he wanted to put them on an LT1 that he currently had, other than that yes the heads will work and the cam (if it's just the cam) will work but in a 305.....eh
