383 with 305 flexplate
Old Mar 12, 2009 | 09:41 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
plain and simple will it work
i have the flexplate off my 305 and the flexplate that came with my 383 stroker kit doesnt bolt to my torq converter
budget doesnt really allow me to buy a new converter so will this work the kit uses a stock 400 flexplate and its just a stock replacement 305 flexplate
thnx
zig
Old Mar 12, 2009 | 10:14 PM
jupetto's Avatar
Re: 383 with 305 flexplate
I am not positive but I am going to say no.I have a 400 flexplate on my 383.
Old Mar 12, 2009 | 10:19 PM
bart91406's Avatar
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
The flexplate may physically bolt up, but you can only use it if your motor is internally balnced, some 383s are and some are not. The way to tell is to look at your 383 flexplate and see if there is a balance weight welded to it or not. If there is no weight, than your 305 flexplate should work, otherwise you will have to buy a new 400 flexplate, I believe they only cost about 20 bucks anyway.
EDIT
Now I see that the kit calls for a 400 flexplate, no, you can not use the 305 flexplate, you can buy the smaller diameter flexplate for a 400 so that it will bolt to your converter, it will just have to be orderd through sumit rather than bought at autozone I imagine
Old Mar 12, 2009 | 10:34 PM
ziggy89's Avatar
Engine: 383
yea i keep readin up on it and thats what im finding out for the most part
i havent actully seen it yet since my old man pulled the motor out today at his shop while i was at work (kinda sux only bein able to work on your project once a week cause its not at home) so yeai guess ill just have to in vest in a flywheel
thnx bart
84z96L31vortec
Aug 20, 2017 12:16 AM
5spdcamaro
Aug 28, 2015 02:12 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
gwade12
Aug 8, 2015 08:17 AM
Leggman1
Aug 6, 2015 04:15 AM
