Camshaft Remove/Install Question????
Old Mar 15, 2009 | 01:15 AM
Chronic9901's Avatar
Hey guys, I have a 86 trans am 305. I have the top and front of the engine torn down. I'm in the process of doing the timing chain camshaft/lifters. So the question I ask is can i pull the camshaft out the front without pulling the engine??? My haynes book says i can, but the autozone repair guide says i can't. So who has done it, and what tips n tricks can you pass along. It seems like I have enough room with the radiator pulled but i'm not sure.
Old Mar 18, 2009 | 03:44 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Camshaft Remove/Install Question????
You should be able to. You have the new cam? Measure the length and make sure you can line it up with the front of the engine. With the rad removed you only have some bracing to deal with, shouldn't be an issue.
Old Mar 18, 2009 | 04:18 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Sometimes it's easier to undo the motor mount bolt on one side and slightly raise one side of the engine. But I've done it without.
Old Apr 23, 2009 | 02:00 PM
midnightebwx's Avatar
Car: 1984 TA
Engine: 355 SBC Mild cam.
Transmission: 5 speed
Axle/Gears: Stock
How long did it take you for the install?
Old May 15, 2009 | 02:57 PM
Car: 1984 TA
Axle/Gears: Stock
time frame?? i would guess a solid weekend?
Old May 15, 2009 | 03:19 PM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
I took a cam out with the motor in the car... wasnt bad at all. although, nothing went back in because I found metal dust everywhere so out the motor came. I would plan on a full day to do the project give or take a few hours depending your level of experience.
blackroc68
Sep 1, 2015 08:01 PM
midge54
Aug 29, 2015 09:51 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Jake_92RS
Aug 17, 2015 09:42 AM
redmaroz
Aug 16, 2015 11:40 PM
