engine swap wires everywhere
Old Mar 19, 2009 | 09:38 AM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
alright guys im moving right along in my 305 to 383 swap the 305 is out now my question is its a 91 tbi car and i have wires everywhere. i would like to make my gauges work starter that sort of stuff but as far as the computer goes im tossing it out the window
so is there any place to look to see whats wat such as a hayes manuel or sumthing i want it in depth. or am i just gunna have to spend the time to go through all the wires and do it that way
thnx
zig
Old Mar 19, 2009 | 10:22 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Remove the passenger side kick panel. Remove the ECM from its mounting place under the dash. Disconnect the harness from the ECM that runs to the kick panel. Remove the clip that holds the harness bulkhead connector to the body panel.
From the passenger wheelwell, remove the plastic liner. The ECM harness is behind it. Pull the harness out of the passenger compartment and wheelwell and into the engine compartment.
Now follow that harness wherever it goes and remove anything that it goes to. It will also go to the transmission (if automatic), so unclip that connector and pull it into the engine compartment. There will probably be bolted P-clamps holding parts of the harness to the engine or chassis. If any leg of the harness goes to the bulkhead connectors in the rear driver's side corner of the engine compartment, separate the wires for each (you don't need to cut anything but tape to do this) and keep the ones that go to the rear corner in place.
Now remove the harness from the engine compartment. Everything you need for your engine operation and gauges goes to that rear corner set of connectors.
You now have a clean, illegal-for-street-use-anywhere-in-the-United-States, engine compartment. If you have automatic transmission, you will need to provide a means to lock up the torque converter clutch.
Old Mar 19, 2009 | 11:27 AM
ziggy89's Avatar
Engine: 383
Re: engine swap wires everywhere
yea the tcc is being takin care of when i do the rebuild on the trans not that it matters i lost my speedo gears about a year ago and it hasnt locked up since
so everything except for that rear corner
thnx
zig
Old Mar 19, 2009 | 12:28 PM
ziggy89's Avatar
Engine: 383
is it just the two connectors on the pcm and the one that goes where ever behind the passanger side dash pannel
Old Mar 19, 2009 | 02:50 PM
five7kid's Avatar
Correct. But, if you only remove the one going to the engine compartment and put the ECM back in, your in-tank electric fuel pump will work. As will VATS.
Old Mar 19, 2009 | 03:54 PM
ziggy89's Avatar
Engine: 383
all three conectors splice together and run wires in to the engine compartment
Old Mar 19, 2009 | 06:36 PM
five7kid's Avatar
Take out whatever goes to the engine compartment through the kick panel.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
